volt meter
Cman
08-24-2008 13:42:12
I have installed a voltage guage on my AC B. As it turns out it is a battery condition guage.
This guage stays on about 12.5 with the switch off, turn the switch on and it registers no different. Crank engine and it moves to about 13.5 to 14. Seems to be working, but I question it staying on all the time. Other volt guages I have installed on different tractors parks to the extreme left with the switch off.
The B has an alternator and everything seems to be working right.
Any advise will be appreciated..... ..... ....
Den N Ms
08-24-2008 20:33:55
 Re: volt meter in reply to Cman, 08-24-2008 13:42:12
Cman,If you want you could wire it up to ignition on side of a switch.But the drain on a volt gauge is very minute,so it would take a long time to drain the battery.
El Toro
08-24-2008 16:50:06
If it isn't draining the battery I wouldn't worry about it. Hal
