Company Logo (800) 853-2651 Shop Now
Clutch lock
Al S
08-22-2008 07:18:35
My Allis has a clutch lock. Should it be used only for cold wx starting and starting from the ground position ?? Is it recommended to be used while in storage ?? Thanks for responding to my Q.
old
08-22-2008 09:26:10
 Re: Clutch lock in reply to Al S, 08-22-2008 07:18:35
Clutch lock is used in a number of ways. One for hand starting so you have less load on things so you can spin the engine over better. Also if you have a problem with the clutch sticking from sitting for a long time it can be used to help that problem.
Bill in IL
08-22-2008 07:59:34
The only reason I use mine is when running the belt pulley and have to hook up by myself whereas I have to be off the tractor and the pulley not running.
Not saying I am the expert but when starting you can take it out of gear and during storage you do not want your clutch springs to be compressed.
