Company Logo (800) 853-2651 Shop Now
1948 AC B wiring
BIGJOE
08-17-2008 10:07:50
is a 1948 Allis Chalmers B positive ground or negative ground? I am finishing a restoration started by my grandpa and have no clue if its a negative or positive. Thanks for your time.
John T
08-17-2008 10:49:46
 Re: 1948 AC B wiring in reply to BIGJOE, 08-17-2008 10:07:50
To be safe I would Polarize the Genny BEFORE you start her up.
John T
old
08-17-2008 10:13:39
It came new + ground but if it has been converted to 12 volts its most likely - ground
BIGJOE
08-17-2008 10:20:44
 Re: 1948 AC B wiring in reply to old, 08-17-2008 10:13:39
ok so i am looking at a positive ground tractor i guess. sweet! thanks for the fast reply sir.
old
08-17-2008 11:34:55
 Re: 1948 AC B wiring in reply to BIGJOE, 08-17-2008 10:20:44
Yep till the late 50s, early 60s almost all tractors where + ground if they where 6 volts.
TOM OWENS
08-18-2008 17:44:48
 Re: 1948 AC B wiring in reply to old, 08-17-2008 11:34:55
1947 b only pops and some smoke, but will not start. the F mark and #1 are right. need all the help i can get. thanks,tom
old
08-18-2008 18:49:28
 Re: 1948 AC B wiring in reply to TOM OWENS, 08-18-2008 17:44:48
Mag or distributor?? Hard to help with out more info. If its a mag drop me an e-mail and I'll send you the manual for that mag.
TOM OWENS
08-18-2008 20:00:00
 Re: 1948 AC B wiring in reply to old, 08-18-2008 18:49:28
IT IS A DISTRIBUTOR, ALSO IT IS A C NOT A B. IT IS STILL 6 VOLT,BUT IT HAS POS. GROUND. I DONT THINK THAT IS RIGHT. THANK'S. TOM
old
08-18-2008 21:18:43
 Re: 1948 AC B wiring in reply to TOM OWENS, 08-18-2008 20:00:00
+ ground is as it should be and it was that way when new. Now as far as spark you could have a simple bad switch, bad wires, bad coil, dirty points, cracked cap bad rotor or the insulator going in the side of the distributor could be bad
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
Latest Ad: Looking for a Farmall super h steering housing the big cast piece in front [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
