Allis Chalmers Discussion Forum |
model B
Author |
[Modern View] |
pilot199
08-15-2008 20:07:14
I'm restoring a '39 Model B that has a right-angled gear box attached to the rear shaft allowing the pulley to turn in horizantal fashion.This gear box appears to have been installed using make shift bracing. It looks to be very homemade & unusual. Does anyone have info. as to how these are properly mounted? Thanks, Gary
steve(ill)
08-16-2008 06:00:05
Re: model B in reply to pilot199, 08-15-2008 20:07:14
yes, there should be a tapered key shaft sticking out the left side of the rear case, at an angle to the rear splined PTO. that is the factory setup. anything mounted on the rear pto shaft external is not a factory setup.
pilot199
08-16-2008 07:04:23
Re: model B in reply to steve(ill), 08-16-2008 06:00:05
Yes I can tell that this was added, Any idea as to what the mounting brackets are supposed to look like? Gary
Uncle Ernie
08-16-2008 05:44:01
The pulley and gearbox on a B are in a casting that bolts to the back of the transmission along with the hydraulics. Can you add a picture of what you have?
pilot199
08-16-2008 21:02:09
Re: model B in reply to Uncle Ernie, 08-16-2008 05:44:01
  The attached photo shows the right angle gearbox mounted on my tractor. The problem I have is how to keep this thing mounted properly & still do an authentic restoration. The framework supporting it is just a patchwork of channel & angle iron. I plan to mount the 42" mower back on the tractor when done. Any info. would be appreciated. Thanks, Gary
ddl
08-17-2008 09:28:57
Re: model B in reply to pilot199, 08-16-2008 21:02:09
I think you answered your own question when you said it was added. The original implements that were meant to run with the tractor would not have needed that pulley i suspect so i would take it off and restore the tractor then with the implements it was suppose to run. Ingenious idea though, does it run a mower?
pilot199
08-17-2008 09:40:22
Re: model B in reply to ddl, 08-17-2008 09:28:57
Yes, this turns an old Woods 42" cut belly mower. I was hoping to find a better way to support this gearbox & continue using it because the way it is presently you must remove it in order to change the drive belt! Also, there was an added, heavy channel iron frame which supported this whole thing. I think I'll take your suggestion & remove it & start over. I need to find print outs or photos of these tractors with belly mowers that I can copy. Thanks, Gary
ddl
08-17-2008 09:28:30
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1951 Farmall H - by The Red (John Fritz). I have been a collector of Farmall tractors since 1990 when I first obtained part of the family farm in Eastern Indiana. My current collection includes a 1938 F20, 1945 H, 1946 H, and the recently purchased 1951 H. This article will focus on what I encountered and what I did to bring the 1951 NEAR DEATH Farmall H back to life.
... [Read Article]
Latest Ad:
2 old Dodge Pickup Trucks not running mostly complete early 50s flathead 6cyl stepside box side entry hoods Price 1200 both.
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
