not sure whether I have a B or C allis chalmer wide wheel
Dustin Dellinge
08-14-2008 18:14:51
the tractor has seial number E123570 in front of gear shifter and the gearshift pattern is #2 on top left,#1 on top right,#3 on bottom left, and Reverse on bottom right.Serial number on engine is CE181901PA, thanks for the help.
Old Ford Mechanic
08-14-2008 18:30:46
 Re: not sure whether I have a B or C allis chalmer wide w... in reply to Dustin Dellinger, 08-14-2008 18:14:51
More info.Your tractor if is a B is a 1953 year model.
Old Ford Mechanic
08-14-2008 18:25:57
Look at that # again.The E is possibly a B.If it is then you do indeed have an AC model B tractor.
Robert Mull
08-15-2008 09:30:22
 Re: not sure whether I have a B or C allis chalmer wide w... in reply to Old Ford Mechanic, 08-14-2008 18:25:57
If the steering arm coming out of the steering box under the gas tank is pointed down and is connected to the left front wheel it is a "B". If it is pointing up it is a "C"
