b final drive
ee
08-12-2008 06:29:36
What oil or grease goes in the final drive.
thanks
ee
08-13-2008 10:45:57
 Re: b final drive in reply to ee, 08-12-2008 06:29:36
thanks guys
steve(ill)
08-12-2008 15:15:55
most guys use 8 quarts of hytrans type fluid in the trans/ differential/hydraulic compartment. the "final drive" is acutally the pan under the bull gear, covered by the rear wheel rim. you have to remove the pan to clean it out. 80w-90 gear lube is a good thing to use now. what you take out will probably look like road tar.
old
08-12-2008 08:13:59
I use a hyd-tran type oil. Any of them work as long as they meet Allis specs.
