Re: wd45 gear shift slipping out of 3rd
Phil
12-07-1999 17:17:16
In reply to your question. After owning many A.C.
tractors we've learn't that they all have the same problem up to the 200 series.The cause is longterm grinding of the gears.The synchromesh splines get
worn out at the end. (the tooth ends get rounded off) Since the shifting mechanism doesn't go very far into the gear compared to other tractors a little wear will make this happen.Usually in the gears that are most commonly used such as the third gear due to their gearing ratio. The correction to this problem is to either(for a quick fix) shim behind the gear that is jumping out or (good fix) replacing it completely.
