Anybody own a 7060
Farmin in Brown
08-04-2008 19:10:57
Would like to find someone with 7060 to maybe get some air-conditioning info off of.
Drawbar419
08-05-2008 13:20:04
 Re: Anybody own a 7060 in reply to Farmin in Brownwood, 08-04-2008 19:10:57
What info do you need? Freeze 12 is good and there are retro fit brackets made for changing compressor to Sanden from Fridgeair. R-12 is good if your lucky enough to get some and have a good working system already.
Farmin in Brownwood
08-05-2008 17:58:52
 Re: Anybody own a 7060 in reply to Drawbar419, 08-05-2008 13:20:04
Well, to start I was going to see if it would take a charge, If not other things have to be looked at, and I guess parts availability is what I'm driven at, in case I have to start replacing certain items. Any suggestions there?
Bill in IL
08-05-2008 05:12:59
Go search for Freeze-12. Its a R-12 replacement. No oil change and its better than 134.
Farmin in Brownwood
08-05-2008 18:00:13
 Re: Anybody own a 7060 in reply to Bill in IL, 08-05-2008 05:12:59
Thanks for your response Bill, I'll do that.
glr62
08-04-2008 19:12:05
have at it
Farmin in Brownwood
08-04-2008 19:58:44
 Re: Anybody own a 7060 in reply to glr62, 08-04-2008 19:12:05
Hey, how are ya. Just bought a 7060 last week and air blows, but of course not cold. I'm wondering if I should re-charge with r-12 or up grade to r134. Thats assuming charging is what it needs.
massey333
08-05-2008 14:00:45
 Re: Anybody own a 7060 in reply to Farmin in Brownwood, 08-04-2008 19:58:44
Only an idea,but the 40s,45s and 60s had a lot of failures with the heater valves not shutting off all the way.Might look at that first.
Farmin in Brownwood
08-05-2008 18:01:23
 Re: Anybody own a 7060 in reply to massey333, 08-05-2008 14:00:45
If that sucker don't take a charge, I'll sure do it. Thanks for the info.
glr62
08-04-2008 20:10:26
i would up grade
Bob
08-05-2008 09:59:49
 Re: Anybody own a 7060 in reply to glr62, 08-04-2008 20:10:26
R-134 is NOT an "UPGRADE"!
It is, at best, a "retrofit".
glr62
08-05-2008 20:39:41
 Re: Anybody own a 7060 in reply to Bob, 08-05-2008 09:59:49
just put 134a fitings on and chsrge. less than $10/00. it will work no mattrr what goverent says
Farmin in Brownwood
08-05-2008 18:03:27
Well, I just hope a charge is all it needs, If not any suggestions as to go for A.C. parts?
Farmin in Brownwood
08-04-2008 20:19:57
I guess theres a kit or something for upgrading?
glr62
08-05-2008 00:21:40
 Re: Anybody own a 7060 in reply to Farmin in Brownwood, 08-04-2008 20:19:57
134a fittings, drier and change compressor oil
