B tapered wheel bolts
Kevin (So.MN)
07-13-2008 20:55:48
My wife bought an AC B and it has cast one piece front wheel and hub. The rim is fastened to this with four 7/16"x2" square tapered head bolts on each wheel. The tractor had a spare tire from a car bolted through the hub that we got rid of. The other hub only had three of the right bolts. So we are short five bolts. Any help finding some would be appreciated. The B was in sad shape when she got it,but with the help of this forum by reading other posts its taking shape. New clutch, seals, tires and paint its looking pretty good. Thank you.
David Maddux
07-14-2008 04:48:28
 Re: B tapered wheel bolts in reply to Kevin (So.MN), 07-13-2008 20:55:48
There is only one place that I know of that has these, Tony Carbaugh. He is loacated over at unoficialallis.com. It might be tonystractors.com
Kevin (So.MN)
07-14-2008 20:11:22
 Re: B tapered wheel bolts in reply to David Maddux, 07-14-2008 04:48:28
Thanks David, I'll send him an E-mail.
old
07-13-2008 21:28:15
AGCO should have them or try a place that sells trailers since a lot of trailers use that type of lug bolt
Kevin (So.MN)
07-13-2008 22:31:22
 Re: B tapered wheel bolts in reply to old, 07-13-2008 21:28:15
Thank you. I'll check out those places tomorrow.
