Company Logo (800) 853-2651 Shop Now
B Allis
Brent S
07-07-2008 05:32:12
Anyone know the best fix for a block that has a crack in it? I was told J.B. weld. didnt know if there was anything better that would work. Thanks
mlpankey
07-09-2008 16:36:11
 Re: B Allis in reply to Brent S, 07-07-2008 05:32:12
Yes there is a better fix than jb weld but its somewhat expensive .Belzona 111 supermetal its keep heads blocks even radiators from going to the scrap yard. the last i bought was 194.00 but it lasts a while didnt mention my air compressor tank froze and busted smeared it over the spiderweb cracks and she still holds 160 psi.
Ed Hodge
07-07-2008 19:17:11
i used body filler with fiberglass i last about 3 year nee you have to do it over
Dick L
07-07-2008 07:15:10
Is this a running tractor or something you are starting on?
Brent S
07-07-2008 07:33:17
 Re: B Allis in reply to Dick L, 07-07-2008 07:15:10
just got it and it needs to be restored. Was running until the guy left it outside with water in it. pretty good condition but needs paint, tires and rims.
Dick L
07-07-2008 09:44:21
 Re: B Allis in reply to Brent S, 07-07-2008 07:33:17
The reason I ask was if it is not running and you have not yet taken the head off you may want to before making a decision about patching the block. Unless you want to be number correct any engine block from a B, C, or CA will work. All the same block except for numbers and the bump on the left side of the CA. All internal parts interchange.
old
07-07-2008 06:29:22
JB weld might work but its just a patch that may or may not hold. Best fix of course is to find a good used block to replace the one you have. I have 2 of them here that are good but need to have sleeves etc
Brent S
07-07-2008 06:40:48
 Re: B Allis in reply to old, 07-07-2008 06:29:22
This B is a 1939 i believe, it has no power anything. willany block work or do you have to have a year that is the same? any idea what this might be worth fixed up?
old
07-07-2008 07:26:34
 Re: B Allis in reply to Brent S, 07-07-2008 06:40:48
I'm not sure as to what years had the smaller engine but if its not one of those any block from a B/C/CA will fit unless like I said its the smaller engine and even then a complete engine from the others will bolt right up
Dick L
07-07-2008 06:27:39
Where is the crack?
Brent S
07-07-2008 06:32:13
 Re: B Allis in reply to Dick L, 07-07-2008 06:27:39
It is on the carb side and its about 8 inches long. It goes just above the block drain in back of the carb.
Dick L
07-07-2008 06:49:45
 Re: B Allis in reply to Brent S, 07-07-2008 06:32:13
Vee it out and get some JB weld water putty or what ever brand the have on the shelf where you shop. I bought mine a Walmart in the automotive section. I just bought a new stick there but was another btand. Fantastic stuff. Does not drupe. Just cut off a small amount about an inch at a time. It will get hard in your hand if you do. You can push down in a crack with your thumb.
Years a go I bought a car with a freeze crack like that and it had been patched with Bondo and never leaked in all the time I drove it.
