Spark Plugs for WD
Karl in MD
06-30-2008 05:12:17
My WD has J8C Champions in it, and they foul constantly. The WD does use some oil. Can anyone give me an Autolite or other number that would be a little hotter than the J8Cs? Has anyone else had numereous bad experiences with Champions like I have had? Years ago they were good plugs, now it seems like they don't last, and some are bad right out of the box. Thanks in advance for any help.
Jeff Z.
07-04-2008 12:05:15
 Re: Spark Plugs for WD in reply to Karl in MD, 06-30-2008 05:12:17
The Autolite 295 Is the same as the Champion J8C. I would try the Autolite 303 to start. You may also try anti-foul ends for the plugs.
acplowboy
07-03-2008 19:01:45
i heard the autolite 295 was the best plug for an ac tractor
Rock_Picker(MO)
07-02-2008 06:33:06
If oil is fouling your plugs, another option is to buy some "spark plug extenders".....just a small fitting that goes between the head and spark plug..... ...one cylinder on my WD pumps a bit of oil..... ..using an extender solves the problem.....as a matter of routine I clean the plugs once per year with a sandblaster....FWIW..... ..RP
Larry from Maryland
06-30-2008 16:36:28
If you try a bunch of differant plugs and they ALL tend to foul i would suspect a bad coil. Thats what i found.
David Grubb
06-30-2008 06:37:02
The plug of choice is currently the Autolite brand. The hottest operating plug for your WD would be the 308.
Kentb of SWMO
06-30-2008 06:34:03
I figure the Champion haters would be out in force. I use them all of the rime without problem. I just got a set of N-3C's for the LP fueled G262 power unit on my C-II Gleaner. If you tractor is burning some oil try a J-12. You may have to use the extended tip version which might help you fouling problem. J-12YC.
Kent
Karl in MD
06-30-2008 08:06:01
 Re: Spark Plugs for WD in reply to Kentb of SWMO, 06-30-2008 06:34:03
Thanks, guys. Please understand, I don't hate any brand, but I haven't had any luck with Champions lately. For 25 years, that was all I used, but when I started having problems, I tried other brands, and they worked better. The first problem I ever had with them was in 2-cyl Deeres. That's when I tried Autolites. I don't think that the corporations care about the quality of their brand names as much anymore. I think that they believe that advertising and brand loyalty will carry them through.
jd plowboy
06-30-2008 12:42:09
 Re: Spark Plugs for WD in reply to Karl in MD, 06-30-2008 08:06:01
i run AC 45 plugs in my wd45. that is the best plug i found and have not had any problems.i know of two other wd45 that are running them also with no problems.
