Allis Chalmers Discussion Forum |
WD won't start
Author |
[Modern View] |
James Glendening
06-29-2008 07:42:13
I recently moved my distributor and alternator from my 49 WD to a 53 WD that had the old 6 volt system on it. I aligned both motors to top dead center before making the switch. My 49 ran great but had transmission problems which is why I made the switch. I have power out of the coil, the starter spins and I get grey/blue smoke out the exhaust but won't start. Did I manage to get the distributor out of time during the switch or did I forget something?
El Toro
06-30-2008 07:46:05
Re: WD won't start in reply to James Glendening, 06-29-2008 07:42:13
Bring No1 piston near the radiator to TDC on the compression stroke. Both valves should be closed on that cylinder when the piston is at TDC.Look to see where your pointing. If its not at the No1 plug tower you need to pull it and rotate the rotor so it is at No1 and reinstall. Hal
El Toro
06-30-2008 07:48:04
Re: WD won't start in reply to El Toro, 06-30-2008 07:46:05
Look to see where the rotor is pointing once its at TDC. Hal
BobHnwOh
06-29-2008 15:18:49
Set the motor at top dead center,then check to see that the rotor is close to the # 1 post in the distributor,if it doesn't start rotate dist. 180 degrees!
old
06-29-2008 08:12:02
You may have it out of time or you may have your plug wires on wrong. I would start by switching the wire 180 on the cap. I.E. take the wire from one side and move it across the coil wire to the other side of the cap. It may start for you it may not and back fire. If it back fires then you know you where close the first time.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1951 Farmall H - by The Red (John Fritz). I have been a collector of Farmall tractors since 1990 when I first obtained part of the family farm in Eastern Indiana. My current collection includes a 1938 F20, 1945 H, 1946 H, and the recently purchased 1951 H. This article will focus on what I encountered and what I did to bring the 1951 NEAR DEATH Farmall H back to life.
... [Read Article]
Latest Ad:
2 old Dodge Pickup Trucks not running mostly complete early 50s flathead 6cyl stepside box side entry hoods Price 1200 both.
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
