Company Logo (800) 853-2651 Shop Now
1951 A-C CA model-assumed generator problem?
Alfred White
06-24-2008 08:34:18
new battery does not hold charge..suspect generator or solenoid which appears to have been recently replaced. That is the solenoid appears to have been replaced recently. Acquired the tractor just two months ago.
steve(ill)
06-26-2008 18:28:00
 Re: 1951 A-C CA model-assumed generator problem? in reply to Alfred White, 06-24-2008 08:34:18
to test the generator, ground the "F" terminal to the frame to bypass light switch resistor. if tht works, you have a bad ground. next jumper around the cutout relay, which is really connecting the A terminal of the generator to the amp meter. you can also put a volt meter across the two terminals of the generator with the F grounded and relay bypassed and see what voltage you have. if both of those tests fail, the generator is bad.
Dick L
06-24-2008 10:46:53
Do you mean the cut out on the generator? Is it still 6 volt?
If it has a solenoid it was added but it still should not be a draw down there. If it has been changed to a 12 Volt GM alternator it could have an internal short.
Or not wired correctly in the box under the steering wheel
old
06-24-2008 10:43:51
Pull one of the battery cable off then put a meter or test light between the battery post and cable. If you get a reading then you have something that is taking a draw on the battery if you don't then you have a new bad battery. If you get a reading take one wire off at a time till you find where the draw is coming from
Latest Ad: Wanted 13x28 power adjust rim for D 17 allis in NE Nebraska [More Ads]
