6060 clutch
don1
06-16-2008 07:51:52
I have an engine out of a 6080 allis challmers and a complete 6060 allis chalmers tractor without an engine or clutch that I want to put together.Does anyone know any details about the compatibility? I donot have a flywheel or a pressure plate and need to find the proper parts to make the transition. Some one told me that ther is 3 different clutchs for a 6060.
Edpap
06-17-2008 19:03:17
 Re: 6060 clutch in reply to don1, 06-16-2008 07:51:52
Hello Don,
I am showing one 11" dual stage clutch for a 6060 and one 12 1/4" dual stage clutch for the 6080. If i am reading your post right you will need a flywheel and clutch to go with the 6060 I can get get all those parts but the one thing I can't answer is if a 6060 flywheel will bolt up to a 6080 engine. I can tell you that the trans input shafts are different. It might be possible to put a 6060 clutch on the 6080 flywheel but you would have to measure the OD of the flywheel to the bell housing. I would be looking at the bellhousing bolt patern if that is off then you might better forget the whole thing. If you want some prices send me an email or goto to abcrepairparts and contact me.
Good Luck Ed
I was just about to send this and thought I should look up the engines they are both the same 200 ci model 433T so I would bet the the flywheel will interchange. so this might work.
