Re: AC "C" Magneto
Mike Huber
08-20-1998 05:48:33
: Does anyone know the correct point gap for a FMJ Mag?
: The spark seems a little weak when you crank it over by hand, : just wanted to make sure the gap is correct.
: Also, will it hurt to run the generator without being wired to the electrical : system. I would like to run the tractor before I paint and put the final : touches on it. Basically I just need the generator to act as an idler to help circulate : the water
The point Gap is 020 I don't believe in would not hurt any thing to run the generator with out being wired God luck Mike Huber
