ac 200 amp meter always charging.
cob_crusher
06-09-2008 11:19:53
rebuilt alternator two years ago. is producing
14.4 volts DC. installed new voltage regulator.
is always showing 15 - 20 amps. did not do so
before. batteries are full of water and crank
aok. amp guage is 2 years old. what should i look
at next ?
Joe(TX)
06-10-2008 09:10:06
 Re: ac 200 amp meter always charging. in reply to cob_crusher, 06-09-2008 11:19:53
Make sure the ground wire on the regulator goes to a good ground and not just to the hood.
steve(ill)
06-09-2008 18:57:43
if the battery is low, charging at 20 amps is o.k. after about 10-15 minutes it should be down to 5 amps. if it stays at 20 amps too long, you will boil the battery dry. if the battery is low, charge it up. if it is charged, then the voltage regulator is bad.--- make sure your terminals are good and good ground.
Texas Denny
06-09-2008 12:41:36
If your voltage holds at 14.4 volts, I wouldn't do anything. I had one do that and it eventually came down when the battery was fully charged but it took a while.
Texas Denny
06-09-2008 12:41:28
