Allis Chalmers Discussion Forum |
firing order
Author |
[Modern View] |
mikeintn
06-08-2008 15:14:33
Can someone tell me the firing order on 1936 WC, I just trying to start one that been setting, hand crank, so I pulled it, but its popping out the ex. like the wires are wrong, I looked in the book I have and it said 1-2-4-3, but it dont seem right. Thanks: Mike
mikeintn
06-09-2008 05:28:11
Re: firing order in reply to mikeintn, 06-08-2008 15:14:33
Thanks for all the input, 1 is top nexts to engine, that whats cap got, then I did wire it clockwise, 1 2 4 3, I've forgot with out looking, but I know its the older mag. just got parts for it, point con. coil, I think [K], I know it dont make sense, but I took plug out, and the rotor is under number one, took valve cover off valves working ok, pull it a couple of times pops a lot out ex. sounds just like wired wrong, but I guess not, I think I'll just try it again, maybe the carb. could do it, It was froz up bad.
old
06-08-2008 18:18:36
1, 2, 4, 3 as per the I-T manual. As a matter of fact all the Allis tractors from the B up to the WD45 used the same firing order. Which would include. B, C, WC, WD, and WD45
leroy in ne
06-08-2008 16:49:28
don't know if this will be of any use but run into a similar situtation several years ago. after pulling a non runner about a mile we found that the original mag had been replaced with a different brand and rotor turned the opposite direction. switched wiring order for this, pulled less than 2 feet and had a sweet runner. leroy
JMS/.MN
06-08-2008 15:43:40
Firing order is 1-2-4-3. Usually cast into the housing that the magneto bolts to. Issue is- where is Number one wire installed? Sometimes top left, sometimes top right, rotation is CW, when viewed from the rear. Try both of those positions first. Otherwise, do the finger in the #1 hole, compression stroke, see where the rotor in the mag is pointing. Try all wire location options before tearing down the engine to see if the timing is set wrong at the cam gear. KISS formula. Sounds like it is trying to fire- good sign for a simple fix.
papab
06-08-2008 15:35:09
kstractor
06-08-2008 16:15:16
Re: firing order in reply to papab, 06-08-2008 15:35:09
Most 4cyl firing orders are 1-3-4-2 A.C was different 1-2-4-3
mlpankey
06-11-2008 15:42:07
Re: firing order in reply to kstractor, 06-08-2008 16:15:16
hmmm i thought ford tractors firing order was 1243 also interesting to know ive been wiring them up wrong must be how i bought the last for 400 it had a miss that the owner couldnt get out of it .allis firing order fixed that ford right up .
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Case Farm Equipment - by Jeremy Sweeten. My name is Jeremy Sweeten and I am currently a junior at Purdue University. I am takin a dual major in Agriculture Systems Management and Agronomy. I am from North Central Indiana, Miami County to be exact. My dad teaches for Marion Community School Systems an outdoor lab called Asherwood. We live there to manage the place. They just happen to have a Case 311 with a Triple Range transmission. I grew up mowing, pushing snow, and hauling maple sap with it. In 1986 my parents bought an old,
... [Read Article]
Latest Ad:
JD starter weights for 10,20 series 75ea JD small green fender toolbox with lid 25 right and left cylinder holders,can ship
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
