AC C Finish Mower
Jim Hunter
06-07-2008 06:53:24
I want to use my AC C with a 5 ft pull behind finish mower. Is there something I can install between PTO and mower so I can shut off mower before I raise it. Also any other advice for this install would be appreciated
Steve in N.J.
06-13-2008 05:45:31
 Re: AC C Finish Mower in reply to Jim Hunter, 06-07-2008 06:53:24
Jim,
I pull a self powered (9HP)4 foot finish mower behind my B to do my 2 acre lawn. I have a remote kill switch mounted under the seat so I can shut the engine down on the finish mower if need be. I don't use the pto being the mower is self powered. Works out great!
Steve@B&B
Carbonfibers
06-07-2008 10:25:31
You can use a self powered pull behind mower. I do not know if someone makes a 5 foot one.
Wayne
old
06-07-2008 08:24:23
One thing you will want is an ORC but as far as a way to lift and stop the mower that would be a hard thing to come by. Now if you added an external hyd pump and a valve body it could be done but thats about the only way I can think of
