Company Logo (800) 853-2651 Shop Now
AC Model B cast oil pans
gus grant
06-05-2008 14:31:27
Greeting from New Zealand
I have removed the pans from the bottom of the case behind the rear wheels as they were rusty and in need of treatment. I intend to refit them with new gaskets and bolts but I cannot find any reference to what grade of oil I need.Can someone please advise and is there anthing that I have to be aware of when I refit the pans.
I would appreciate your help on this.
Cheers
Gus
TexMac
06-05-2008 21:23:36
 Re: AC Model B cast oil pans in reply to gus grant, 06-05-2008 14:31:27
FWIW - an old time retired Allis mechanic told me to use the thick gaskets from AGCO to ensure that the pans would clear the gears if they got a little dent. Said the gears were pretty close and would wear a hole through the pans before you noticed. I did RTV my cork gaskets when I replaced them and so far no problems.
Gus Grant
06-06-2008 15:19:40
 Re: AC Model B cast oil pans in reply to TexMac, 06-05-2008 21:23:36
Thanks Tex
Sounds like a good tip and as I have the cork gaskets already cut, I think I will go along with your suggestion and see what happens.
A big thank you to you guys that have helped me out. N.Z. is a long way from U.S.A. and it can be a bit lonely out here when it comes to A.C. tractors. There is no A.C. agents and most of the people I speak to have never heard of the make.
I am very impressed by the way the forum works and with the replies received.
Once again many thanks
Gus
steve(ill)
06-05-2008 19:01:26
i reinstall the pans with a good bead of RTV sealer, and no gasket. as Denny said, 80 w90 gear lube is the stuff.
Gus Grant
06-05-2008 19:50:48
 Re: AC Model B cast oil pans in reply to steve(ill), 06-05-2008 19:01:26
Thanks Steve.
I was going to do both, a new gasket with a smear of rtv on both sides of the gasket. But I will take your advice.
Mant thanks
Gus
Texas Denny
06-05-2008 15:18:43
90W high pressure gear oil or better.
gus grant
06-05-2008 15:31:31
 Re: AC Model B cast oil pans in reply to Texas Denny, 06-05-2008 15:18:43
Thanks Danny for your quick reply. I hope to refit them this weekend.
Thanks again
Gus
