Company Logo (800) 853-2651 Shop Now
Allis B electrical problem
marsh
06-05-2008 09:39:33
accidently grounded out negitive battery post while putting on battery top tray lost power to starter and distribator cant find problem
Dick L
06-05-2008 10:48:04
 Re: Allis B electrical problem in reply to marsh, 06-05-2008 09:39:33
If it didn't open up the circuit in the battery it has to be in one of the battery cables.
old
06-05-2008 09:57:00
First check the battery cables on both ends of both of them. Shorting like that at times brakes the connection there. If there good clean and tight then check the wiring going to the switch because you may have smoked one of those wires. I'm guessing its still 6 volt + ground from what you have said by the way. It helps use help you if you tell us if its 6 or 12 volt and which way its grounded
Today's Featured Article - Identifying Tractor Smells - by Curtis Von Fange. We are continuing our series on learning to talk the language of our tractor. Since we can’t actually talk to our tractors, though some of the older sect of farmers might disagree, we use our five physical senses to observe and construe what our iron age friends are trying to tell us. We have already talked about some of the colors the unit might leave as clues to its well-being. Now we are going to use our noses to diagnose particular smells. ELECTRICAL SMELLS ... [Read Article]
Latest Ad: JD factory 3pt hitch fits 2 cyl 20 and 30 series tractor and 2 JD rear wts for late 2cyl and new gen Price 2000 for pkg calls only [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
