carbonfibers
FYI if anyone is thinking about purchasing a brush mower for the Allis B, I just bought a DR 17 HP pull behind brush mower. I strongly recommend it for pastures with high grass, small saplings, and brush. If you slow the tractor down for any reason, the mower still has full power. You can run the allis in second at any speed you want. The mower handles it, at least so far. It only cuts 44 inches wide but you can make it up with a little speed if you are on relatively smooth ground.
Using the DR pull behind, I do not have to remove the woods belly mower to cut the pasture.
I am very happy with it.
Wayne
Wayne
