Company Logo (800) 853-2651 Shop Now
wc motor with ford 302 pistons
compoundtractors
05-31-2008 18:40:43
has any one ever heard of a wc motor running for 302 pistons they are both the same bore does any one know if they will work?
compoundtractors
06-01-2008 17:45:45
 Re: wc motor with ford 302 pistons in reply to compoundtractors, 05-31-2008 18:40:43
the stroke is only 4.25 with a wd45 crank is there any way to get that much stroke
mlpankey
06-02-2008 08:34:28
 Re: wc motor with ford 302 pistons in reply to compoundtractors, 06-01-2008 17:45:45
yeap theres a way to stroke the crank . a 5.8 with 7 5/8 rods would be getting close . most run bigger bore than ford pistons . ive heard of a 6. 250 stroke with 4.750 bore running around . 4 5/8 bore is common 5.5 - 6 inch strokes are the norm to.
mlpankey
06-01-2008 06:37:25
With a 6.250 stroke or longer rods they could work.
dboll
05-31-2008 19:47:41
I would think the comp. distance would be alot shorter than the AC pistons, might work ok with a stroker crank
