Posted by mkirsch on June 23, 2014 at 07:52:51 from (65.199.189.6):
In Reply to: McCormick Farmall Cub posted by Huskerdawg on June 22, 2014 at 17:03:23:
Yup, look for a (probably used-to-be) shiny plate on the lower right front corner of the tractor, near where the steering shaft enters the front end. It may be painted over, or it may be missing.
If it is missing you will never find the actual serial number. However there will be a serial number stamped into the engine block that *should* be close, unless someone has replaced the engine block.
Casting date codes indeed indicate that it is *probably* a 1948 model, but it could be an early 1949. "11 11 R" means November 11, 1948, and IH was often a couple months ahead of production with the castings.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
