Posted by Dean Olson on April 13, 2014 at 11:47:51 from (107.129.21.153):
In Reply to: Re: farmall 200 posted by dewy on April 13, 2014 at 06:26:24:
Rebuild the auxiliary control valve on the side of the touch control. All fluid has to go through there to or from the reservoir.
There"s a block that both hydraulic lines go through. Located between the seat and shifter. It designed to slow down lowering the fast hitch so you don"t drop a heavy implement and damage it. Bypass that. I bypassed mine years ago thinking I"d fix it. Still on my to do list. As the fast hitch works so well I may never get it done.
In my limited experience with 3 super C"s and a 200 that will solve your problem.
So far any cylinder I"ve had leak down has leaked externally and was obvious that was the problem.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
