Auction
Re: Farmall 450
Posted by Janicholson on March 01, 2014 at 16:16:23 from (74.60.94.18):
In Reply to: Re: Farmall 450 posted by DVF on March 01, 2014 at 15:04:15:
That would reduce the flow into the oil if the leak is not a compression leak from combustion gasses into the coolant. There are test kits from auto stores that test radiators for the presence of exhaust gasses. Cheap and accurate.
A cracked bore casting is possible allowing coolant to leak down between the sleeves and the cast bore. The coolant will be found dripping from the interface between the sleeve and the block. The solution for that is to have the block bored for a repair sleeve then that sleeve bored (and counterbored for the sleeve ring) to accept the original sleeve that is in the tractor.
That is a very successful and permanent repair.
If it is not a compression leak, I would try barsleak liquid to seal it up till the time it can be repaired correctly (follow the directions) Jim
Today's Featured Article - It's Alright Where It Is! - by Anthony West. I have a tale of a different kind to tell. Whilst rooting in the hedge bottoms this week I had cause to visit Chapel lane Farm, the home of an eccentric gentleman by the name of Austin Kendall. I had heard rumours that an old Case Model C was languishing away in the back of one of the outbuildings there. So off I went in search of what would turn out to be a very rare and unusual tractor. Mr Kendall is an excitable chap to say the least. He is amongst the last of a dying breed of farmer who ... [Read Article]
Latest Ad: Super WD9. [More Ads]
