Posted by tom dowling on March 01, 2014 at 07:39:49 from (96.241.138.42):
In Reply to: Re: Farmall 450 posted by DVF on February 28, 2014 at 21:50:14:
Milky oil? Do you keep the tractor outside? I thought I had a blown gasket or cracked head/block also, turned out it was rain water going in the seams of the muffler and around the threads of the pipe at the manifold. A flapper or can on the muffler isn't good enough. Loosen the oil drain plug a bit and see if you are getting green or clear water. If it's green your outa luck, if it's clear then it's rain water and you can change the oil, run tractor till warmed up and change it again. Then let it sit there and run an hour or so to steam out any remaining water. It worked good for me.
Today's Featured Article - It Can't Be Done! - A Tractor Story - by Neil Campbell. I'll never forget the time back when I was a boy baling hay on our Farm in Big Rapid, Michigan. The most memorable event that took place was a trip up the steepest incline on the farm pulling an old New-Idea baler with a pony-motor for power and a haywagon. I had just talked my Dad into buying an old John Deere B with 6-speeds ahead and I was real proud of it, except it was a little smaller than the Case tractor that we normally
... [Read Article]
Latest Ad:
Rebuilt Injection pump for J D 1010. Call or text for pictures or more imformation.free shipping.U.S. No core charge
[More Ads]
