On the lever where it connects to the rod going to the hydraulic unit, there are two nuts. Loosen the outer nut then tighten the inner nut some and try the lever. If the friction washer is ok, you can adjust the friction so that it holds. If it works, then tighten the outer nut while holding the inner nut. If this doesn't work, then you will need a new friction washer. You can make them out of 1/16" cork gasket material.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
