Posted by pete 23 on February 18, 2014 at 10:04:48 from (74.33.78.170):
In Reply to: 656 Hydro posted by 504 on February 17, 2014 at 19:24:03:
There is no stop other than the end of the slot in quadrant. How is the neutral adjustment. Lever should move same amount in forward as reverse to start movement of tractor. Often times the whole quadrant gets loose , cracked or broken corners off lower mount so it does not limit lever properly.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
