Posted by pete 23 on February 18, 2014 at 09:58:28 from (74.33.78.170):
In Reply to: Farmall H carb posted by Martin H on February 18, 2014 at 07:30:07:
That brass part you have circled is a plug. Not a service item as it is used to plug one of the internal passages during the manufacturing of the carburetor. When you say sputtering, I guess you mean it spits and sputters when you go from low engine speed to high speed. What we term as cold blooded. Pretty hard to cure completely and if you did the engine would probably run pretty rich after it got up to speed. Far as idle jet, the actual jet is quite a ways down inside of the long jet so if the screwdriver slot is damaged it most likely still does not affect the jet. Broke a few off in my day. Have a tap to restore threads as needed. Also, never heard of a good rebuild kit for an H. I always buy the parts I want separately. Lot are no longer available.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
