Posted by Centex Farmall on January 29, 2014 at 08:47:15 from (72.105.164.142):
In Reply to: Super M LP posted by 62c100 on January 28, 2014 at 08:50:00:
Also you'll want to fix up a nurse tank in case you get low in the field. There will be a "T" under there that has one leg capped off. It is a flair fitting. You should be able to find a ready made propane hose with that flair on one end and the other end setup to go on a BBQ tank.
When you hook it up just make sure your tank valves are closed and then open the BBQ tank and off you go.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
