Someone put a welsh plug style heater in the water jacket cover (behind the carb) on my M. It has threads and they drilled a hole and bonded the nut to the cover. The heater screws into that. If you give it a couple of hours it does an outstanding job. I want to say it is a 400 watt, but it puts the heat exactly where it is needed not in a hose a foot from the engine. I am very impressed with the way it works.
Google it. It should be the same size as a "freeze plug" heater but have threads. Find a nut that will thread on it and put that on the cover. It isn't welded on so it must be epoxied or something. It is the slickest thing I have seen and works well. If it were me I would weld the nut to the cover although it would be tough because that metal would be easy to burn through.
I would have looked at it closer the last time I had the cover off, but I was afraid to mess with it much. If it ain't broke.
Today's Featured Article - It Can't Be Done! - A Tractor Story - by Neil Campbell. I'll never forget the time back when I was a boy baling hay on our Farm in Big Rapid, Michigan. The most memorable event that took place was a trip up the steepest incline on the farm pulling an old New-Idea baler with a pony-motor for power and a haywagon. I had just talked my Dad into buying an old John Deere B with 6-speeds ahead and I was real proud of it, except it was a little smaller than the Case tractor that we normally
... [Read Article]
Latest Ad:
Rebuilt Injection pump for J D 1010. Call or text for pictures or more imformation.free shipping.U.S. No core charge
[More Ads]
