Posted by Raner on October 03, 2013 at 04:15:04 from (173.175.94.231):
In Reply to: F20 coolant leak posted by doehmke on October 01, 2013 at 19:03:55:
I use alumaseal powder it works very well and quick...
I sealed up my heater core on my old Dodge Cummins 10 years ago still holding on leak...
My old B tracker was dripping water between the engine and clutch housing I figured it was a freeze plug leaking used alumaseal and fixed it right up that has been around 15 years back...
Yesterday I used on my H it had it was dripping antifreeze from the lower right side of radiator could have been a tube or the tank sealed it up in 10 minutes...You might give it a try before you start pulling studs you will only be out around $3.50 or so...
The best way to use it is run the engine with no radiator cap or with a very loose radiator cap till water is hot or circulating in other words till the thermostat opens...Then add alumaseal tighten radiator cap and run the engine till leak stops works pretty quick but run the engine at least 30 minutes to an hour that should be long enough to fix all the leaks or seeps in your cooling system...
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
