Posted by Owen Aaland on October 02, 2013 at 19:00:36 from (216.47.33.123):
In Reply to: H steering posted by bmagee on October 01, 2013 at 15:19:51:
The bearing in the drawing is different than the ones I am familiar with. The shield does not cover the top race on that one. It really doesn't show which race the shield is attached to. The grease will be coming up from the bottom so it has to travel between the lower race and the shield. The larger ID of the top race would allow the greased to be pushed out the top. My guess it that the way I described earlier still leave the larger ID race on top. With that style bearing the shield is pinched between the upper race and the casting so the grease still has to enter between the shield and the lower race, go past the balls, and exit the top. If the grease enters from the top like on a wide front the principle is still the same, the grease just goes in the opposite direction through the bearing.
When dealing with thrust bearings where the shield covers one race it make no sense to lift the axle before greasing. If you take the pressure off the trust bearing the grease is allowed to bypass the bearing rather than being forced through it.
Today's Featured Article - It Can't Be Done! - A Tractor Story - by Neil Campbell. I'll never forget the time back when I was a boy baling hay on our Farm in Big Rapid, Michigan. The most memorable event that took place was a trip up the steepest incline on the farm pulling an old New-Idea baler with a pony-motor for power and a haywagon. I had just talked my Dad into buying an old John Deere B with 6-speeds ahead and I was real proud of it, except it was a little smaller than the Case tractor that we normally
... [Read Article]
Latest Ad:
Rebuilt Injection pump for J D 1010. Call or text for pictures or more imformation.free shipping.U.S. No core charge
[More Ads]
