In the IH set up the priority valve is in the block that bolts on the steering support post toward the front of the tractor and replaces the one already there. Also contains the pressure regulator and safety valve system. Also need the control valve that goes to the support post and a passage plug. Also fittings and a U shaped pipe. Yes they can be rebuilt. Aftermarket priority valves come in various shapes, sizes and pressure ratings and would need to be plumbed into the existing line from the pump to the reservoir. Then the pressure outlets plumbed to the steering unit and hydraulic pressure line. Return line from the steering unit would go to the drain opening on the reservoir. If its a priority valve with its own relief valve a extra line would need to go to the return.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
