Posted by Janicholson on August 29, 2013 at 19:08:03 from (74.60.94.18):
In Reply to: IH 300 Utility posted by akconnection on August 29, 2013 at 18:36:30:
Three components affect the engine: Fuel compression and correctly timed spark. The symptom as described shines on fuel as the first issue to check. Shut off the fuel at the bottom of the tank/sediment bowl. Remove the fuel line at the carburetor. It is a compound fitting and has a strainer in it at the fitting Do not use poor tools, use wrenches that fit and if necessary a Line wrench (looks like a C with the ability to touch the nut with many points of contact) When it is off, look at that screen if plugged, clean it) Put a clean 2# coffee can under the line and turn on the fuel. It should run out in a PEE stream and do so for at least 2 minutes. If not the line, sediment bowl, or tank supply pipe is plugged. This symptom allows only enough fuel to get to the carb for partial replacement of the fuel used. If it sis for 10 minutes the carb will be full. It will run till the fuel begins to lower in the carb, then start to miss and choking just adds what little gas remains in the carb for a brief burst of running before stopping. The pipe leading to the tank can be the source of grief, it is necessary to drain the tank to get at it (obviously slowly as the line may be plugged pretty badly) The second issue is a failing coil. These will be hotter than a fire cracker, and are internally shorted and cause very similar issues. Check for spark immediately when it quits if no spark, there it is. Put a spare plug on a plug wire and ground the base of the plug, and watch it as someone cranks the engine (neutral brakes on). Shade or darkness helps see the spark. Bright blue and crisp is desired. Yellow and thready is bad. Fuel first, then coil. Compression is good or it would not run well at all. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
