Posted by Pete76NY on July 01, 2013 at 21:38:17 from (66.194.51.226):
In Reply to: paint posted by butch49 on June 30, 2013 at 21:24:01:
I don't know why people think you need suppled air to use hardner, a good quality mask works fine, heck even use that for epoxy primer, just have to make sure you replace the filters periodically. But to answer your question; yes I have used hardener with Rustoleum paint, but not Red, I used it with their Gray on a 2N Ford, the hardener made it very slick and shined like crazy, but the paint faded very quickly and alot (looks like primer now.) One of the BIG reasons for using hardner is to make the paint last longer, and it certainly didn't in this case, since it does seem to make the OEM paints: Deere and IH last well I assume it was the paint so have never used Rustoleum again. As far as the hardner goes, if you look at the type of paint; ie. synthetic enamel, ya can get hardener for that type about anywhere: TSC, AutoZone, Colours... One thing I will say is that when I redo a tractor, I often use cheaper paint to do the areas that will be hidden once assembled, and just to powder in those real hard to get to areas, so when I shoot with the better paint I don't have to keep shooting one little area just to get it green, or red or what ever. Usually I grab some TSC stuff for this. When I was putting our '48 JD A back together this spring, I went to TSC and they had that new "Majic" stuff, I grabbed some JD green, was so impressed with how easy it sprayed, and how good it looked, I went back and bought a gallon and some hardener and shot the whole tractor. WOW is it easy to work with, and it shines like crazy, pulled it up next to the JD 70 which was the last one I shot, and ya cannot tell it from JD Classic Green! The test will be how long it lasts, as that crap TSC had before lasted about a week before fading, but it's been 2-3 months and so far so good! Of course I used JD yellow on the wheels...just seen too many nasty looking JD wheels to tangle with any other. Yell at me when you go to do the rims on your IH, I have a Toyota paint number that is spot on for that original look!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
