Posted by IH fan on June 28, 2013 at 17:34:32 from (72.209.181.231):
In Reply to: SMTA posted by DeltaRed on June 28, 2013 at 15:55:18:
I'm with you, the pump was no doubt toast before it was plugged. The only way you could run it without ruining it and not be connected to the hydraulic system would be to loop the pressure and suction ports with a long enough fluid filled hose to allow for some expantion as the fluid heated up from normal circulation. Still not the best idea, but better than running it plugged.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
Looking 4 set 9 bolt hubs 3 1/8 inch to fit 60 to 4010 jd
[More Ads]
