Posted by Janicholson on June 28, 2013 at 15:53:49 from (74.60.94.18):
In Reply to: SMTA posted by Mhmcp on June 28, 2013 at 14:40:54:
Make sure it sure it is primed before abandoning hope. Put 15 PSI in the reservoir to push oil into the pump. If no luck you might try the following. Use hydraulic rated fittings and hoses. If you run a hose from the small port to a plain 1/4 turn ball valve, and the exhaust from the valve to the intake port, then fill it with oil, the pump should labor the engine(at slow Idle) when the valve is slowly and briefly edged toward closed. If no change in engine pitch the pump is toast. Running it closed is not at all good. To really check it you need a flow rater. Jim
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
