Posted by Jim Becker on June 25, 2013 at 18:25:01 from (173.57.153.141):
In Reply to: Generator 12 or 6 volt posted by jgstrickland on June 25, 2013 at 15:40:34:
That generator number is correct for the original 6-volt cut-out based charging system. Now that you have used emery cloth on the cut-out contacts it will probably fail before long. You might be able to save it by recleaning the contacts with a point file then cleaning them with contact cleaner while holding them open. Otherwise plan on buying a new one. You have a fair chance if it is only a cut-out. If you used emory cloth on voltage regulator contacts, you might as well drop it in the trash now.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
