Posted by Owen Aaland on June 17, 2013 at 15:31:36 from (216.47.35.170):
In Reply to: Hydraulic Pump posted by slifnom on June 17, 2013 at 13:54:00:
If your pump is worn so that it is low on performance the repair kit will not normally give you very good service. If the pump has much wear on it the bushings will be worn and very little wear is necessary before the gears start to rub on the housing and will cut out the aluminum. The kit only contains the side wear plates and soft parts.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
