Okay, I've got everything timed up now with the bolt's swapped. When I first started it up again after I retimed, it still didn't seem like it wanted to rev all the way up, so I backed it down and slowly bumped up the throttle until I got up to PTO speed. I stepped out to scope things out and noticed the return line off the injectors was spraying out at one of the banjo fittings at one injector. I shut it down, tightened it up and fired it up again. Now the throttle response seems way different then it used to be. I'm just guessing it's due to the pump being turned up. I don't know if there was some blockage in a line when I first fired it up or if it was from sitting for 5 months. I took a video of the tach and the throttle lever because it doesn't seem normal. It's a little shaky and it's hard to tell exactly whats going on with the play in the lever. Hopefully I can get the youtube link attached.
If it is turned up more then I need, how hard is it to turn it down?
Thanks again for all the help! I would have never thought to swap or check those bolts.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
