TractorLinks.com
Re: gas fouling # 4 plug
Posted by gene bender on May 01, 2013 at 15:50:39 from (67.55.226.151):
In Reply to: gas fouling # 4 plug posted by Bob Reineke on May 01, 2013 at 12:17:27:
The problem is not the gas you probably have a bad wire or maybe the valves in that cycl arent set correct. You can also take that plug and replace from another cycl that would also tell you if the plug was bad but gas is not the problem. How does that plug look when it quits firing good like other post says maybe a bad cap. But if you change plugs from another cycl that will prove the problem is the wire or bad set on the valves. BTDT with other used tractor ive boughttill i found the problem. Just do one thing at a time so you can find the problem.
Name:
E-Mail:
Subject:
Comments:
Optional Link URL:
Link Title:
Optional Image URL:
Optional Video Title:
Optional Video Embed:
Email Notification: If you check this box, email will be sent to you whenever someone replies to this message. Your email address must be entered above to receive notification. This notification will be cancelled automatically after 2 weeks.
