Posted by mkirsch on April 20, 2013 at 22:46:13 from (64.80.110.74):
In Reply to: Farmall 140 posted by jbarrineau on April 19, 2013 at 19:11:57:
It ain't the ethanol fuel. That engine was designed in the 1930's and will run on good rotgut whiskey and chicken squeezin's.
You've got a fuel supply problem or an ignition problem. Try working the choke when it starts acting up. If you can get the problem to clear up with the choke then it's a fuel supply problem.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
