You could make one out of PVC it fits the shaft OD and is just wide enough to cover the seal and then the belt pulley will hold it in place. If you dont have a pulley make it long enough to cover the splines and use a cap screw to hold it in place. Make sure the OD of what ever you use is large enough to fit against the seals ID.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
