Posted by pete 23 on February 16, 2013 at 09:11:54 from (74.47.40.242):
In Reply to: 1466 posted by Chris Reinmann on February 15, 2013 at 18:35:00:
Early models were about 135 factory advertised, later ones about 146 pto. Sure you can set them up. Sky is the limit. People with 200 hp 1466 are definetely not glueing that tractor to the ground and using all of that horse power. Ask them how much fuel they burn per hour. You won't get more than about 15 hp per hour per gal of fuel. Do the math. Replaced a ton of rear ends in those tractor with factory set pumps.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
