Re: Ih460 wiring ,coil question
Posted by mkirsch on January 31, 2013 at 05:42:20 from (64.80.110.75):
In Reply to: Ih460 wiring ,coil question posted by LarryNMO on January 29, 2013 at 18:10:31:
6V or 12V... Well, do you want it "original" or do you want to simplify the system?
If you want original, get a 6V coil, remove the jumper wire from the resistor, and set up the "boost" circuit like Tractor Vet described earlier.
If you want simple, get a 12V coil, and completely REMOVE the ballast resistor.
Latest Ad: Super WD9. [More Ads]
