I am building a complete harness for a Farmall 460 gasser at thins time . You have the black wire coming from the key switch to the resistor and a wire from the other terminal to the coil NOW what you need is a white 14ga. wire from the R TERMINAL ON THE STARTER SOLENOID TO THE wire side to the coil . or after the resistor , this way it gets a shot of 12 volts to the points for starting .
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
