Inside the pump, there is a lever that latch's on a machined ledge. Normally , they don't hold good enough so unusual for it to hold too good. Over the outlet of the relief valve is a cap that push's this lever when the relief valve open and allows the oil to come through hole in end of relief valve. Your problem has to be in that area. Bent lever or cap is getting stuck between relief valve and lever,(cocking off to the side). There again, usually when that lever bends the cap pops off and ends up in bottom of pump some place. Lever is mallable so it can be straightened and a little fileing or grind on right spot to make it latch good but readily easy to trip. The headed pin the lever pivots on can also become bent causing your problem.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
