Posted by sflem849 on January 25, 2013 at 15:49:31 from (69.197.84.39):
In Reply to: 39 farmall h posted by farmallboy15 on January 25, 2013 at 14:14:50:
I know, what I am saying is radiator shutters, heat shields, and most of the other distillate stuff was the same for the entire production run. Steering wheels, decks, mag shuoff (or is it only the little guys that run a cable?) and seat assemblies were not. Those items are a lot more important than the distillate items.
ie The radiator shutters were always SHUTTER AND OPERATING BAR, complete (Mfr. no. 17250) from day one. At least there is no serial number break to show any difference. Maybe the operating rod was different.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
Looking 4 set 9 bolt hubs 3 1/8 inch to fit 60 to 4010 jd
[More Ads]
