When an engine is powerful enough to slip the clutch, and the clutch is new (my take on your statement above) a heavier duty clutch cover is needed. Sometimes a puck style driven disk will grab better and work with standard Pressure plate. Rebuilding the clutch Pressure plate with different primary springs is another option. If you try the rebuild option, stock springs can be shimmed to provide that additional force if (and only if) the coils are not forced together into coil bind when the pedal is fully depressed. Valve spring shims of the correct diameter will work. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
